stoney_titan
- Feb 19, 2007
I want to use this DVD player with a separate 100-150gb external hard drive.
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16882641285
I see in the comments that it requires a Fat32 formatted drive to work properly, which windows can only do 32gb partitions.
Would the easiest solution be to borrow a buddies Mac and format it into Fat32 that way? Will my Vista rig accept it ok?
Also, does anyone have any recommendations on a drive? Some even come as Fat32 but I don't want to buy based on that. And will a 5400rpm drive be efficient for streaming high-def movies?
If there is a better player in the 50-75 dollar range I also wouldn't mind a recommendation.
(Sorry for the bazillion questions.)
