seniorpaul
- Aug 8, 2005
Last summer i used a bunch of spare parts that i had lying around and built a half-arsed HTPC. Now i think i'd like to put one together that's more functional. I'm fairly comfortable with all my hardware choices, with the execption of the TV tuners. Even after spending a couple of days here reading reviews and whatnot, i'm a little puzzeled about a few things. Hopefully someone here can clear some things up.
1. I'd like to have my HTPC hooked up to my cable. Do i need to have multiple cable boxes in order to record multiple programs simultaniously using two TV capture cards (Hauppauge PVR-150's)? If so, would i STILL need two cable boxes if i were to use a Hauppauge PVR-500? I'm not sure how it would make a difference, but i've been reading some conflicting reviews.
2. Are there any workarounds to avoid needing multiple cableboxs to record multiple shows simultansiouly?
3. It's my understanding that there isn't any way to capture HDTV programing from a cable box. Is this accurate? How far off is a cablecard capture device?
any help is appreatiated.
