Sideroxylon
- Jun 7, 2004
I'm going to put a custom WC system in a Silverstone Temjin case and I'm thinking of going with dual single 120mm radiators from Danger Den. One in front and one in back. I'm trying not to cut this case to install a dual 120mm rad but it looks like it could be done fairly easy if I had to.
So, I'm thinking my loop would be: res-pump-front rad-cpu-back rad-northbridge-res.
Or: res-pump-front rad-cpu-nb-back rad-res.
Any potential problems/advantages with either of those setups?? And your thoughts on the single dual 120mm rad vs. the 2 single 120mm rads.
Thanks
Thanks
