I am planning on getting the Asus Eee PC:
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220246
And i was going to get an SD card to expand it's memory. I was wondering if i should just get a larger card, say 16gb, that had standard read/write speed like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211245
Or go with an ultra2 card card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820171348
Basically, will i notice a big difference with the speed?
Thanks,
Jackal
Thanks,
Jackal
