Im looking into getting a Radiator Fan for my DangerDen Black Ice Xtreme II Black with Shrouds, and I have had my eye on this Fan:
KingWin 120mm Double Ball Bearing Case Fan
- Max Air Flow (CFM): 79.14
- Noise (dBA): 30
- Nominal Speed (RPM): 2000
Link: http://www.newegg.com/app/ViewProductDesc.asp?description=11-999-965&depa=1
I just want some suggestions if this fan will do any good for my radiator. I will need to get two of them to fit the radiator. If this isnt suffecient, then what fan do you guys recommend that has a good amount of CFM and low noise?
Thanks a lot!
- Noise (dBA): 30
Thanks a lot!
