iownyou14 said:Im talking about fitting it on the top of the case, not on the 5 1/2 bays. Like the fans intake air from the top, into the case.
i can fit the black ice extreme II int eh bottom of na X- dreamer 2.Alex41290 said:you could never dream of fitting it in there...well, depends what you mean
4 total = 2 drives + 2 empty
OR
6 total = 2 drives + 4 empty
i'm gonna assume the first
If that's the case, you could always mount it on top of ur case, but ur not gonna fit a dual 120mm rad in the drive bays..
think of it this way: 2x120mm = 240mm and they are bigger than a 120mm fan, so its gonna be like 275mm (estimate)...good luck fitting it in your case, unless you have a CM Stacker...but otherwise, you can try.
