So I bought all my Windows Home Server hardware, and I have two 750GB drives that I'd like to setup in a RAID 1 array. As this is my first RAID setup, I have a few questions about it before I do.
As I understand it, in RAID 5 array, the data is split to the hard drives in a proprietary manner. In other words, if the motherboard fails, you couldn't simply pull the drives out of the case and stick them in another computer. You'd have to get the same kind of RAID card to recognize the data off the drives.
Now my question is, is is the same in RAID 1 array? Since it is just mirroring the drive I'd assume that each drive would be a standard NTFS volume that I could just stick into any computer and be compatible, but I wanted to ask on here before I started playing around with it.
