Hello,
I was wondering if there was a raid card that had hardware raid 6 that supported 3TB drives for around $100?
Or am I stuck with software raid? If so what would you recommend?
how about dell perc H700 with BBU and 512M cache memory. I see $99 including shipping.
the item# 111413830912 on 3bay.
perc 700 and 800 manual -> http://www.dell.com/downloads/global/products/pvaul/en/perc-technical-guidebook.pdf
Awesome, thanks for recommending this. I would of never considered Dell since in the past these were locked to drives with Dell Firmware installed only, it seems that is no longer the case.
Follow up question: How does this compare to a LSI MegaRAID 9260CV-4i?
Both seem to support 3TB+ drives with the LSI being a tad more expensive.
