What drivers do you all use with your Raptors?
I'm going to do a fresh install, and I don't know whether or not I should install any Nvidia drivers, the IDE ones or what. Can I only disable NCQ with the nvidia drivers? And will NCQ turn itself back on when I reformat?
I'd really like the best performance I can get, any suggestion to which drivers I should use would be high appreciated.
