cyberslag5k
- Jun 29, 2004
I've had my Mamba (the original, not the 2012) for about a week now, and I'm really struggling to adjust to it. I'm pretty close to just going back to my simple 3-button Logitech optical, but I thought I'd share my issues to see if anyone can offer any insights on them.
1. I feel significantly less precise with this mouse. I think it might be because it's so heavy, and is thus a little unwieldy. It takes me a few adjustments to find a small button or a link or something, whereas before I could just snap right to it. I've upped the DPI to 1600 and added an acceleration of 8, which has helped a bit, but I still find myself frequently saying "I wouldn't have missed that with my old mouse". The higher DPI does help a bit in gaming, but in every day use, the mouse is just feels a bit more awkward.
2. The mouse wheel requires a great deal of pressure to click. It requires me to change my grip slightly get focus the force required to click it, and doing so while moving the mouse is awkward. It often results in my inadvertently right-clicking.
I was hoping that with use these issues would go away. It's been almost a week now. They might have a little bit, but I'm starting to question whether this is the mouse for me.
As far as mousing surfaces go, I was using an ExactMat, but the mouse would go unresponsive for a few seconds if it was ever lifted slightly (something I do frequently), so I bought a Sphex (which is pretty sweet). It still has these issues (I've contacted Razer and am waiting for a reply), but they're better. It doesn't have that problem on a regular table top, but the Sphex makes it super smooth, so I've been using that.
Has anyone else noticed these issues, or anything similar? Are these things that I'll just get used to? Should I change my grip somehow? Or am I just needlessly putting myself through frustration, and should just return to my old mouse which was working fine?
