First off some info.
A Company I do bussiness with is upgrading. Currently they're on 6 machines + Server all on a 16port switch. Now they're moving to new offices and adding 6 more machines. On top of that every office is going to have 3 cat5e jacks(2 data, 1 voice)
All these connections are going to one patch panel(Cept the voice, thatll prob be branched off into the PBX patch)
Now this is a VERY small company. They just cant afford to spend money on a high density switch. Since I haven't delt with Cheap switches before Im asking for your help. My idea was to buy two cheaper 24port switches and cascade them. Would I like a cluster of 2950's or better? yes. but thats not an option here.
We Dont need any sort of vlans or management. Again small network and beyond the machines we're adding theres very little need for future expansion anytimesoon.
Here are my initial Choices. Cheaper is better here in the end. Anyone know anything about these? The linksys obviously has more features listed. All are store and foward. The Cnet and 3net ones both have 2.5mb Buffer The 3Net also seems to have a seperate back port for cascading(I'm guessing)
Is there anything special I need to look for when hooking two cheap switches together? I'm really only familiar with Cisco Equip
CNet CSH-2400 10/100Mbps Fast Ethernet Switch - Retail - $74
http://www.newegg.com/Product/Product.asp?Item=N82E16833171205
3Net ALW-3024T-V1 10/100Mbps Switch - Retail - $66
http://www.newegg.com/Product/Product.asp?Item=N82E16833163003
LINKSYS EF3124 10/100Mbps Switch - Retail - $118
http://www.newegg.com/Product/Product.asp?Item=N82E16833124043
Last Question is Kindof a biggie.
Now we paid to have the new offices wired half way. The other half of the building was still being decided but at the time the server room was already planned and the jacks all ran into the corner where the server room was to be built...... Now a few weeks ago the genius bosses decided they didnt want the server room there. So they moved it 10ft to the left. Our problem is. What do we do if the cable run isnt long enough? We left alot of slack but it might just not be enough for this change.
How would we extend the cable without getting transmission problems. Would a 66/110 Punch block work? Should we use Couplers? or what. I'm really at a loss of what to do here.
I tell you management decisions really piss me off.
Please help.
Please help.
