I just finished my first HTPC build. I want to play some games on my big TV now. I need a wireless mouse and keyboard preferably in a set. What should I buy that will give me good response at about 15ft away from the box. Thanks in advance.
none of the standard wireless stuff will work fromt hat distance. you'll need blue tooth or one of those pricey IR sets. the gyration is suppowsed to have good range too.
The gyration units have great range though if you plan on playing games I wouldn't recommend them. They tend to have a slower response time than an IR or BT unit.
usb extension cables can solve the 15 ft problem... just move the receiver a little closer to the sofa when you want to play (it's what I have to do with my MS Desktop Elite.)
I've also thought about running usb cables around the baseboards to a usb hub hidden somewhere near the sofa, but what can I say... I'm lazy
