Well just setup my new comp about a few weeks ago, and now I figure I might start shopping for some accessories.
First off I need to replace my MX510, I've had it for 3 or 4 years now and the top right of the bottom of the mouse is totally warn where the sticker and stuff is gone, and it's actually starting to wear the plastic. The two rubber feet in that area are gone as well.
Secondly, I've been using the func 1030 for about the same amount of time as the mouse, maybe a bit longer. And it's really gotten worn out, it's gotten extremely rough and moving the mouse takes effort. I prefer the rough side of the pad, so I guess it's no surprise that both mouse and pad are worn out in this way.
Since I like using the rough side of the func pad, can someone recommend a pad similar to this? I know I can just get another func, but I'd like to try something new. Would cloth be similar to the rough side of the func pad?
I was looking at the Razer Deathadder or an MX518, but I think the 518 is fugly (just my opinion of course ). Do you guys think these two are good choices, I figure the MX518 is very similar to the 510 though, which can be a good thing I guess.
I ask all these questions since I'm very sensitive to changes like this. I think I've been sitting in the same position at my computer and my mouse and keyboard haven't moved in 5 years. But I guess this is gonna change
Thanks for any input!
Edit: I guess I should mention budget. I'd prefer to keep the mouse at $50 and below.
Mousepad at around 20ish, lower the better.
