Anybody seen this stuff?
http://www.169time.com/
From what I gather reading the site, they sell pre-modded satellite boxes that have firewire outputs installed on them. It seems that they have a video processor (AVX1) that is installed on a daughtercard that allows you to output via firewire for *ANY* channel that you are able to tune with your HD Sat box.
It's quite pricey, but definitely an option to enable HD recording off of satellite. Anybody tried this or heard of how well it works? It just might be worth $1000 to me to be able to have mythtv record HD content... once I decide on what sat. carrier I want to go with.
Another interesting thing I've run across is this:
http://www.coolstf.com/mpeg/HDTV/index.html
Apparently, dishnetwork made an add-on box for the STB's that re-sends the HD signal as an ATSC stream so that you can pick it up with your built in tuner on your set (or your HD capable tuner card). Yet another tantalizing option.
So how do YOU capture HD content from your satellite provider?
-q
-q
