Some day soon I hope to buy a 3930K to go with the massive amount of stuff I've already bought.
Anyway, I have 32GB of Corsair Vengeance mem, and you need 7 Pro or higher to use it. I have the 7 Home disc with a Pro upgrade code. Should I install the Home version with just 16GB, then install Pro, then the rest of the RAM? Or should I put all 32GB in and go from there?
Will it cause any problems if I just put it all on the board then update the OS after install? I'd really like to put it all in and install after, plus update, but this is Windows, so who knows.
NB - there's no raid setup, but I'll be using a Samsung SSD with nothing else but the optical drive connected. I'll even turn off all other unused connection options in the bios to be sure (ASUS P9X79).
