Hello,
I recently built an Intel rig with the E2180 (stock 2GHz) and overclocked it to 3GHz easily with a simple smidgen bump of vcore one notch. I know this cpu can do 3.2GHz with a bit more vcore just fine. I also have my memory running 5-5-5-15 at 1000MHz. Knowing this, I have an AMD 6400+ staring at me on my desk which is stock at 3.2GHz.
Since receiving the 6400+, my father has been asking me to build him a new computer. I am curious as to whether or not I should keep the E2180 and build a new system with the 6400+ for him or keep the 6400+ and give him the E2180. At stock, which is what they'll be running at if I do give my E2180 to him, I know the AMD will most likely outperform the low-end Intel. But, at 3GHz, or even 3.2GHz if I wish to push it a bit, does the E2180 stand a chance against the AMD? Is it better to have a stock system than an overclocked one if I can get away with it?
How would I go about overclocking the ram on an AMD to get it running 1000MHz or is it not that much different from running 800MHz?
Either way, I'll most likely upgrade my PSU to a Corsair and possibly get 4GB of ram.
Thanks for any input. I probably have a ton more questions on the back-burner.
