Well my bluetooth Logitech diNovo keyboard started to become a bit of a pain with the constant dropping of connections, always sliding around, etc. so I started thinking about a new keyboard.
Picked up a Logitech G510 for the LCD display and because I've been really impressed with the two diNovo keyboards I used. Unfortunately I didn't stop to think that the diNovo were scissor switch keys (very small travel, resists until you push hard enough so it's almost impossible to miss a keystroke). The rubber dome keys on the G510 have a HUGE travel distance and the keypress is not registered until the very end of the press. I missed keys in my first few test sentences typed. Playing a few games with it over the weekend proved the LCD to be a fairly useless gimmick. The BFBC2 app is kind of weird, the only thing I found interesting was the progress to next unlock display, and by interesting I mean distracting as in I kept getting killed while looking at it. And my computer froze/became unresponsive twice with it plugged in, which has never happened otherwise. What's more, the whole thing is very light in construction and the feet pads provide almost no contact/friction with the desk surface so the keyboard slides around as you use it. So the G510 went back.
I picked up a Razer BlackWidow thanks to the ingenious little window on the packaging that lets you fiddle with the arrow keys. The feel of the keys was exactly what I had been missing. Starting with the cherry blue switches, I found a lot to like with this keyboard. Well made, responsive, and some great driver software. And the build quality is really nice, it's very solid, nice fit and finish overall. And it stays put on the desk, wherever you put it that's where it'll stay, an important feature to me. Unfortunately, two problems really turned me off: I like to slap down on the CTRL key, confidently of its position as the bottom left key on the board. Unfortunately the Black Widow has the M5 macro key in the bottom left position, as the 5 macro keys run vertically down the left edge of the board. I found myself constantly thinking I was hitting CTRL-Z when I was actually hitting M5-CTRL. I tried mapping M5 to CTRL to fix it but it didn't help and was seriously slowing me down while doing 3DS MAX as well as writing web code. And finally the F keys are all shifted over by one key for some stupid reason. So F1 is between 2-3 instead of between 1-2. This small deviation really threw me off in BFBC2 and the like. So the Black Widow went back.
I ordered a Das Keyboard Professional Model S. This is the keyboard for me. Bog-standard layout, no dumb features. No drivers necessary. Utterly pristine fit and finish. And it has 2 USB 2.0 ports at the front-right of the keyboard, very useful. I LOVE this keyboard!
But I had a couple conference calls where I was typing mad notes and the key noise was a bit of a problem (I was having a hard time hearing people over my typing at certain times as people on conference can be quiet through no fault of their own). I could just keep the diNovo hooked up and type with that during calls, but I do have a secondary gaming system that could use its own kick-ass mechanical board so I decided to find something with cherry blacks for typing during calls (meaning the cherry blue board will become the back-up board). I bought the Steelseries 6GV2, and have to say I'm quite pleased with it. I cannot fault it in any way. I like the heaviness of the keys. I will be returning it though, simply because I want to have two identical keyboards on my desktop. So I'll be buying another Das Keyboard, this one the Silent model. I'm still debating whether to get blank keys or not. I think I'll go with blank keys for this second Das.
So anyhow, the final result/verdict: Go with Das Keyboard if you want a really well built mechanical keyboard for all-around productivity+gaming systems and don't need any bullshit LCDs, macros, etc.
