RGB Fusion Gigabyte X570 Aorus Elite problem
hossdaddy
Hey guys,
so I tried updating the RGB Fusion software as the colours were off on my G.Skill TridentZ 32 gig kit of rgb 3600 ram. Now the software does not even "see" the ram? I have updated the bios etc but to no avail.
I even tried OpenRGB and it said it could not read info for the ram.
Is this an problem with the mobo itself?
Thanks in advance.
RGB software corrupted memory SPD. There are quite a few instances of this issue being posted in memory support forums of several manufacturers and controller softwares around the web. I cannot attest to the validity of the claims as I just don't use RGB. Thaiphoon burner and AIDA can be used to checksum the spd chips for corruption. Thaiphoon burner can reflash SPD chips of DDR4 if you can get your PC to post with just one of your modules installed and if only 1 module is corrupted (try them both 1 at a time in the correct memory slot). Otherwise it may be RMA or replacement time for your memory.
Thanks for the reply learners permit, I have no Corsair software in my pc.
I have tried another ram klit and the same result.
I tried to download the Thaiphoon Burner and it will not download at all.
