A few hours into initializing, the raid controller will report a drive has failed. This only happens when I try to set up a 7 or 8x array. 6x array initializes and has worked fine for a week. Now a number of potential problems I have already investigated as follows:
Bad drive(s)?
After repeatedly trying to rebuild/init the array the "failed" drive rotates at random. The most recently "failed" drive initialized fine then worked perfectly well as part of a 6x array for days.
PSU problem?
The drives are housed in an external array. I brought in a second PSU and split the drives among them in terms of power. This had no effect.. sometimes the "failed" drive was powered by the second 400watt PSU, sometimes the other.
Heat issues?
I reduced the environmental temperature and brought in an extra 200mm fan just to rule this one out. I noted a failure while no drive was more even warm to the touch.
I have no idea what else could the problem.. the controller itself?
All hardware and software is new and otherwise performs flawlessly. There is no overclocking. I put in a support request email to Highpoint but they are of course closed for the holidays, through Jan 5.
System specs
Was WinXP MCE but now Vista-64 Ultimate SP1
AMD Phenom 8450 tri-core 2.1ghz
ASUS MA378-T bios: 0403
2GB Crucial ballistix ram @ 8500
640GB WD HD
ATI Radeon HD 3600 video
RocketRaid 2322, latest bios ver 1.7, Vista driver ver 1.9
RAID hard drives, 8X Samsung 1TB HD103UI drives
SC-ASAT84XB external SATA HD enclosure w/Two Infiniband Multilane 4X 4-channel SFF-8470 external female connectors; has 300watt PSU from factory
Bad drive(s)?
PSU problem?
Heat issues?
System specs
640GB WD HD
