uss enterprise
- Feb 5, 2009
Hi all,
I want to use the S/pdif header on my mobo, as my receiver does not have optical in.
I found MANY sites on the web stating all I need is a donor RCA cable, and a connector from an old case. Both of which i have.
Simply put one pin to GROUND and body of RCA, and the other pin to OUT and center pin of RCA on the mobo header. Is it really that simple? The work I have no problem with, I just want to make sure I won't damage anything (unless I f up, of course) by doing this. Thanks!
