[Resolved]
Is this safe?
I had to Zip tie my 120mm fan onto my HR-03 plus because the brackets that came with it doesn't fit a 120mm fan.
So, I zip tie the top part.
But then I found out it hangs on the bottom:
This would so hit my wires and X-fi sound card so I decided to zip tie around the whole heat sink to keep it in place.
Well, is this safe? How hot does the heat sink get anyways? Will the zipties "Melt"?
How should I fix this?
Is this safe?
