twonunpackmule
- Sep 27, 2005
I keep getting the Safely Remove Icon in my system try, that ask me to remove my harddrives.
How do i make it go away?
SATA is hot swappable, yes.tilted said:I just built a new system.
I have an MSI NEO4 Platinum and a Raptor.
I see my drive listed under safely remove hardwareon the taskbar?
Did some reading and found this SATA drive is capable of being removed with the system on. Hot Swappable.
Also, write caching is turned on, which it should be. I will find out how to get the lame icon to leave my taskbar.
