I've seen these badboys talked about on a few review sites, and am in for one set myself.
Get It @ Woot.com
You'll Like To Move It, Move It
Is it a boomerang? A neck massager? Some nightmarish, hypertrophied cybersausage? Nay, no, and nope. Its the Saitek A-250 wireless speaker system, and it pulls mysterious signals through the ether to bring glorious music from your computer to the remotest reaches of your home (or up to 98.43 feet from the PC, whichever is nearer).
Tote it with you around the manor, from the study to the billiard room to the conservatory, like Professor Plums lead pipe. The onboard LCD display and volume, play, skip, back, pause, and stop controls let you punch up just the right tune for the occasion. Do the laundry to Dirty Laundry! Listen to Bitchin Camaro while you work on your bitchin Camaro! Have a milkshake with My Milkshake! The possibilities are approximately limitless.
But surely, you scoff, such a mobile electro-music megaphonator certainly suffers a grievous loss of fidelity and presence! Our reply: whered you learn English, Bleak House? As to the speakers, youre dead wrong, Chuzzlewit: thanks to true digital quality 2.1 stereo with active bass, neodymium tweeters, and a dedicated subwoofer, the Saitek A-250 sounds as clear and heavy as a crystal sledgehammer.
If the wireless thing doesnt move you, jack your mp3 player directly into it for a mainline rush of sweet, pure, irresistible sound. After one listen to the Saitek A-250, youll be forced to agree: its milkshake is indeed better than yours.
Warranty: 2 years from Saitek
Features:
- True digital 2.1 stereo delivered through two neodymium tweeters and dedicated subwoofer
- Reliable high-quality wireless link receives and controls PC audio within 30m range (98.43 feet)
- Lighted LCD display and volume, play, skip, back, pause and stop buttons to control your PC
- Easily portable and durable for everyday use all around your home
- Advanced speaker technology with active crossover boosts bass clarity and reduces noise for outstanding audio response
- Wireless connection to PC only, (requires Windows 2000/XP)
- Connect to MP3, CD and portable media players via 3.5mm jack audio cable (provided)
- Speaker technology incorporates aluminium tweeters, front-driven sub and passive port sub enclosure
- Neodymium speaker magnets increase efficiency and reduce magnetic interference
- Requires 4 x AA batteries for up to 24 hours use; includes AC adapter
Get It @ Woot.com
