How can you tell if the battery is going bad
or the phone itself is defective?
Lately, seems that my S4 drains fast and does not charge all the way
to 100%. It may go to 95% or 98% plugged. The phone is 10 months old
with latest updates. I've been using a lay down type charger at times
and that seems to work even worse at recharge. I've let it drain all the way down
no change.
I have Sprint service, should I just take it to them or do something else first?
Don't want to get ripped off, thanks for your advice.
no change.
