Factorxfiles
- May 20, 2006
I just got a new samsung spinpoint F1 HD103UJ, which is a sata 2 1TB drive. My motherboard is an ASUS A8N5X as seen in my sig.
I was looking to replace my old IDE 200g drives. I performed a clean format and install of windows XP to the new drive, which was successful until it restarted, and would then say HAL.DLL is missing or corrupt, and not load the new installation.
I believe the issue lies somewhere in that the motherboard only supports SATA 150, and the drive is SATA 300. Samsung provides a utility to set the drive to SATA 150 mode however, which I have run (both utilities, actually, they have two), but it has not resolved the issue. Here are some things I have done to try and resolve the issue:
1. tried another install disk (known good disk, my current install on the old HD used that disk). same exact problem
2. Expanded and copied over manually HAL.DLL off a known good disk, and my current working xp install on the old drive. same message as before
3. completely reformatted (not quick format) and retried several times
4. changed boot disk order in bios from old HD to new, and back. when set to old HD, gives HAL.DLL message, when set to new HD gives all caps "no system disk found" or some such.
5. Removed old HD's and attempted install with only new HD, which gave a message "error loading operating system" after restart, instead of the HAL.DLL message.
6. did a bit of research, realized mobo does not support SATA 2, and ran samsung's utilities, just incase the drive wasn't auto-switching down to SATA 1. (however I am not sure how to check if the drive is in SATA 1 or 2 mode, so I don't know that it worked)
7. Checked the entire drive with HDtune, all clear. shows only one of my old IDE drives as "bootable" under the information tab. Not sure why or what that means.
8. Drank a bunch of everclear and slept.
I am totally out of ideas or reasons why it would not boot. Windows sees the drive just fine, and I am able to read/write from it without any issues from my old installation on the IDE drive. The bios recognizes it just fine.
The only last thing I can think of is that somehow the other drives are screwing with it, since the message did change when they were not present. But I am at a loss as to what to try next. Any assistance would be GREATLY appreciated.
other relevant info: i am on the latest bios for my motherboard, there are no special sata drivers available on asus's website, and google has provided me with no further solutions. I looked, for several hours.
