SAPPHIRE HD 4670 GDDR4 with Arctic Cooling - Where is it?
Ren H
SAPPHIRE HD 4670 512MB GDDR4 with Arctic Cooling Does anybody know what's happening with this card? Is it going to be released in North America? It was available at newegg and elsewhere last March but I can't find it anywhere. I think it's available in the U.K. at least. This card fits my needs perfectly, fast enough, quiet, and under $100. And the 4670 has extremely low power draw. I'd be buying two of these if I could. http://www1.sapphiretech.com/us/products/products_overview.php?gpid=279&grp=3
http://www.firingsquad.com/hardware/sapphire_radeon_4670_gddr4_review/page10.asp (check the rv740 speculation)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102818
but then I'd want to replace the cooling, unless there's one with sub 20db stock (I believe that's about the rating), so add $20 Cdn for the Artic Cooling sink And the 4670 has extremely low power draw
you can always force the fan to stay at 20%, its VERY quiet at 20% (cant hear the 4870's fan at 20% and i've had it since launch)
These are options, if I can't find the AC 4670, but then the power is also a main attraction for me (should've put that in the original post)
Which brand of 4870 are you using risqu3? (if other than ATI)
I'll just have to wait a little and see if it shows up, I've seen the ddr3 version of the 4670 for about $75 Cdn, but from wha tI've read its fan is very loud. nfg! lol
