Hello all.
I currently own an XPS Gen 2. I was under the impression that the Gen 2 supported SATA-150 hard drives, so I purchased a new Hitachi 200GB 7200RPM SATA-150 2.5" hard drive for it. But, upon cloning my old stock 100GB 7200RPM Hitachi, I discovered that it was ATA/IDE with some sort of converter on the end. A converter that isn't the same as the new SATA drive. I could have SWORN they said it supported SATA.
I talked to tech support, and they said the XPS Gen 2 did not support SATA (?!?), and that there was not a converter. They said I would have to use an external USB converter... Which is stupid and completely defeats the purpose of such a fast drive.
Am I stuck with a 200GB expensive paperweight (or an extremely bottlenecked/overpriced external drive)? Has anyone gotten an SATA drive to work in their XPS Gen 2's INTERNALLY? Is there a converter I can buy?
I am a bit peeved...
-JB
-JB
