Raptor007
- Aug 22, 2004
I'm considering adding an SSD to my computer for swap and temp files. Since none of these files need to be retained after rebooting, I wouldn't even need the drive to be non-volatile; basically, if cheap RAM could be attached to a SATA bus, that would suit my needs just fine.
So, does a fast volatile SATA drive exist? Of course, I'd be happy to use non-volatile SSD, but I figured I'd see if there was something volatile out there; it might be cheaper and/or faster. If not, are there any particular high-speed SSD drives you'd recommend (16GB or bigger)?
