The time has come for me to build a new pc and after using a Ttake Tsunami in my lastest one, I have decided to never buy a case with doors again
So I have narrowed it down to the two cases I would like to use. They are:
Savrow SR-71 (I'd add a window and maybe paint the front)
http://www.savrow.com/site/sr71.html
Coolermaster Praetorian (I'd add a window and maybe some blowholes)
http://www.coolermaster.com/index.p...erial=PAC-T01&other_title=+PAC-T01+Praetorian
I'd get both in black most probably. I believe the Savrow is a version of some old case that's beeen out in the US by Globalwin I think. I like that because it's nice and spacious inside and II've read some very good things about it, but there's only two things about it. The first is that the front is made of plastic and the second is that it looks a bit ugly to me (but nothing a bit of modding couldn' sort out )
The problem with the coolermaster is that it's technical features are nowhere near as good as the SR-71's e.g it only has 80mm fans and so on, but I think it looks nicer from stock and also a big plus (or more a minus for the savrow) is the fact that the front isn't made of plastic.
So which case do you guys think is better? Are there any other cases that you'd suggest?
TIA
Parag
TIA
Parag
