You must assume that the cables for the two PSUs are not the same unless Seasonic tells you otherwise.
Edit: in fact, I think the 520W and 620W were the original line and the 650, 750 and 850 were a later updated line of PSUs, so you should most definitely assume not compatible unless Seasonic tells you otherwise.
