Devistater
- Mar 29, 2001
Seasonic X750 750 Watt
https://www.ewiz.com/detail.php?name=PS-SSX750G&title=SeaSonic-X750-Gold-750W-Power-Supply
$168.99 - $10 (COUPON: APRILFOOLS10) -$4.77 (3% Bing Cashback) = $154.22 shipped
Seasonic X650 650 Watt
https://www.ewiz.com/detail.php?name=PS-SSX650G&title=SeaSonic-X650-Gold-650W-Power-Supply
$153.99 - $10 (COUPON: APRILFOOLS10) -$4.32 (3% Bing Cashback) = $139.67shipped
Free ground shipping.
ewiz charges California tax
Bing lists ewiz/SuperBiiz as 3%-5% cashback
Edit: Bing finally showed my 3% BCB
90%+ efficiency
Fan doesn't run until its needed, so at low power usage, this PSU is silent, and even at higher use, the fan is very quiet.
Has great regulation, rated at 3% across the board by seasonic
(on heavier loads 12v is actually more like 1% or 2%)
5 year warranty
x750 by hardocp
http://www.hardocp.com/article/2009/09/25/seasonic_x_series_x750_power_supply_review/
x650 by jonny guru
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=169
x650 by silentpcreview
http://www.silentpcreview.com/article986-page1.html
x650 by hardwaresecrets
http://www.hardwaresecrets.com/article/837
I took this info from jonnyguru's review:
90%+ efficiency
5 year warranty
x750 by hardocp
x650 by jonny guru
Code:
Modular Cables
ATX connector (560mm) 20+4 pin
4 pin ATX12V connector (570mm) 1
8 pin EPS12V connector (570mm) 2
SATA (350mm+150mm) 2
SATA (440mm+150mm+150mm) 3
SATA (540mm+150mm+150mm) 3
5.25" Drive (350mm+150mm) 2
5.25" Drive (440mm+150mm+150mm) 3
5.25" Drive (540mm+150mm+150mm) 3
3.5" Drive (150mm 5.25-3.5" adaptor) 2
6+2 PCIe (580mm) 4
