Well, I think I'm finally going to pull the trigger on a new system from the ground up. My current box is old enough that with everything I'd *have* to replace, it makes reasonable sense to just buy a few more parts to complete a full new build from the ground up so that I have two functional computers.
The major points of my current computer that I'll be replacing:
-ASUS A8N-SLI Deluxe
-AMD Athlon 64 X2 4800+
-2GB DDR 400 (PC 3200)
-BFG Tech 8800GTX OC
and to answer the sticky:
Gaming
Trying to keep total build within $2,000 - $2,500 but quality of parts is more important than nickels and dimes.
3) Where do you live?
Metro-Detroit area of Michigan
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
-Mid-Tower Case (Looking at: Lian Li PC-V1000Z)
-PSU sufficient enough to handle SLI should I upgrade later (Looking at: Corsair 1000HX)
-Intel Core i7 CPU (Looking at: Intel Core i7 940)
-GeForce 280 Card (Looking at: eVGA GeForce 280 GTX SSC Edition, possible FTW edition)
-X58 Motherboard (Looking at: eVGA X58 Motherboard)
-6GB+ of DDR3 Memory (Looking at: CORSAIR XMS3 6GB (3 x 2GB) DDR3 1333)
-Main/System Hard Drive (Looking at: 150GB Western Digital VelociRaptor WD1500HLFS)
-Good sound card (Looking at: Creative Sound Blaster X-Fi Titanium Fatal1ty)
-Good DVD Burner (Looking at: Samsung SATA SH-S223Q)
I will be reusing one hard drive ("junk/storage" drive), my keyboard, mouse, and display.
-Seagate 7200.10 SATA 320GB (ST332062)
-Logitech G15 Keyboard
-Logitech G5 Mouse
-Dell 2407WFP (24" Widescreen; 1920x1200)
6) Will you be overclocking?
No
7) What size monitor do you have or plan to have?
As above, Dell 2407WFP (24" Widescreen; 1920x1200)
Planning to buy everything by the end of the week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SLI Support - While I won't be using it now, I'd like to have the functionality there for later. RAID or crossfire are not needed. But, I know I'm very limited with the X58 anyway that no matter what I choose I'll be getting a full featured enthusiast/overclocker's board. I'm fine with that.
My main dilemma is the Case and PSU. I would PREFER a module PSU but it is not required. My main goal is to get a PSU that is comfortable enough to handle 2x SLI of a GeForce 280 should I go that route in the future. Right now I'll just be getting the one GeForce 280 card, though. The problem is that it seems most of the ones I'm finding that have sufficient cables are huge 1000w+ like the Corsair 1000HX or the big PC Power and Cooling one. The mid-tower case I'm looking at COULD fit one, but i'd basically have to use the annoying extension bracket and have half the PSU hanging out the back.
I'm willing to change up the PSU or the Case to accommodate. Though I do like the case, so if I could find a (preferred modular) PSU that is small enough to not require the extension bracket yet would support GeForce 280 SLI I'd be set.
The other issue is I'm not ENTIRELY set on a GeForce 280 model. I'm confident I want to keep it eVGA to go with my eVGA motherboard, but it's a toss-up between the "SSC" edition and the "FTW" edition. Seems like a $100 difference (taking into account rebates) on NewEgg, though. So, SSC seems to be the better buy.
I'm open up entirely to input/advice on any part of my "list". I'm not set in stone on anything really. I just picked based off of quick reading of reviews, these forums, and prior brand loyalty for the most part.
Any help at all would be much appreciated. I've been stuck all afternoon going back and forth on GFX Card, PSU, and case... The PSU/Case delimma has been a killer. haha.
Gaming
-Logitech G5 Mouse
No
