Im trying to sell these any BUMPS would be welcome !!!
Contact: [email protected] or PM - PAYPAL ONLY!
If you need more pictures details on either one, just contact me and I will gladly provide more
Selling Koolance water cooling tower and Thermalright XP-120 - Athlon64 & Pentium 4 w fan
Very nice tower, I have 3 water blocks which I will include, I also will include all cables I have for adding different water blocks. Great for overclocking, Silent, no extra fans needed! Good for the beginner/Easy setup
FullTower Chenming Case modified for Koolance.
Includes one Water reservoir
Includes LED read-out for temperature monitoring
Includes Heat Exchange System
Exceptional Pump reliability
Dual Pumps
Complete Alarm system
Auto-Shutdown
Secure CPU Cooler
Extremely low CPU temperatures
Low Fan Noise
Light weight compared to similar designed cases
Low profile coolers and clean design
<----- Removeable drive structures p
INCLUDED (you can purchase any water blocks you may need depending on your system)
CPU WATER BLOCK FOR 478 PIN P4'S
<------ Hard drive cooler will work with all hard drives on the market
< ------ Video cooler - This works on all exsisting video cards (Don't have clips to hold it down - can purchase them from online stores though)
Price: $150 OR Best Offer for tower + Shipping
Thermalright XP-120 - Athlon64 & Pentium 4 w fan - 50$ or offer for both fan and Thermalright
Best air cooling avalible for any CPU
This model is compatible with AMD® Athlon64 3200+ and above, Athlon64 FX 3200+ and above, and Intel® Pentium-4 Socket 478 3.2 GHz and above. Will fit a 120 mm fan.
(5) 6mm heat pipes for efficient heat management
Fins soldered directly to base to ensure effective contact
Light weight and easy installation
Specifications:
Dimensions:
(L x W x H) 110 x 125 x 63 mm
(without fan)
Weight: 370 g
AMD: Athlon64 FX 3200+ and above
Intel: Pentium-4 socket-478 3.2 GHz and above
Sunon Fan
Air Flow 90 CFM
Fan Speed 3100 RPM
Power 4.6 W
Bearing Type Dual Ball Bearing
Fan Size 120x120x25 MM
Noise Level 44.5 db
Dual Pumps
Auto-Shutdown
Secure CPU Cooler
Low Fan Noise
Specifications:
Dimensions:
(without fan)
Weight: 370 g
Sunon Fan
Air Flow 90 CFM
Fan Speed 3100 RPM
Power 4.6 W
Noise Level 44.5 db
