PoweredBySoy
- Nov 14, 2005
Hi, friends. I'm a networking dunce, so I was hoping you could point me in the right direction.
Once I finish remodeling our basement, our home network will consist of the following: 2 PC's on our main-floor office, and then 2 video game consoles in the basement. Now, I would also like the ability to add to that as well - especially the basement, since these days even HDTV's are coming with ethernet ports. And since the basement is currently down to the studs, now's the time to wire it up.
So my questions
1) I was thinking of getting an 8-port router, and then just sending the wires in whichever direction they'd be needed. But then I started reading about switches. Could I just get a 4-port router for the upstairs office (where the cable comes in), then run a single wire to the basement to a 4-port switch? That would give me plenty of ports in both locations, and only require me to fish a single wire through the walls.
2) Should I be looking into a gigabit router? Will I notice any speed difference while using Comcast cable? (would love to get FIOS someday though)
3) If I do go gigabit, do I need to use CAT6 cable? Even if I don't go gigabit at this time, should I wire CAT6 into the baseement anyways - just to be a little more futureproof? I assume CAT6 is completely compatible with CAT5 devices.
Thanks for any advice.
So my questions
