Hello,
I'll soon be buying a wireless router due to my recent purchase of a MacBook. My cable modem and current wired router are located in the basement of my home, where the wireless router will also reside.
The router I'm looking at is the LINKSYS WRT54GL. I only have a budget of $70 or so, and I want a quality router that'll allow me to use the MacBook with good connectivity across the house and, ideally, outside in the yard (though this isn't very important). I also want to secure the connection using 128bit WEP encoding, and don't know how easy/difficult it is to do. It's also crucial that the router includes 4 wired ports, for both my PCs, the 360, and one other port for misc. uses.
Any help is appreciated, and I apologise for my ignorance.
