Tenchi4U said:You can always make one.
Go to a metal dealer, ask a for a 1.25x1.25x0.125 piece of copper. Its about the right dimensions.
the old XP shims may work.
You may want to look into using a HSF that uses the screw/spring method of tensioning (like the MCX6400V), that way it will allow you to decide the amount of tension that is exerted onto the core, unlike the clip-type fasteners found on other HSF.
iddqd said:Well, I'm thinking about getting a mobile 3700+, but it doesn't have an IHS.., And I'm afraid of crushing the core, so I need a shim... Question is, are there any available? Will shims made for AXP's work?
Don't you think a waterblock would be a tad better than a heatsink ^_^ ?Tenchi4U said:nope, right company, wrong model:
Swiftech MCX6400V
http://www.swiftnets.com/assets/images/products/MCX6400-V/MCX6400-V.jpg
Even recommended by [H]
http://www.hardocp.com/article.html?art=NjAxLDE=
Thanks! Does anyone know, though how high is the core above the surface of the PCB? (how thick it is). I might end up making my own shim/buying an XP one...BillR said:The way the mounting works on a 64 there is very little need for a shim. Even the spring clip retainers apply pressure pretty evenly. A bit of care as always, push straight down on the HSF while you latch it, but the new mounting system makes chiping your chip pretty hard.
Luck
iddqd said:Don't you think a waterblock would be a tad better than a heatsink ^_^ ?
Umm. Who the fuck do you take me for?Tenchi4U said:You're messing with me, right?
A water block is only usable if you are using a water cooling setup.
There is no need for profanity, I have been civil with you thus far, I would expect the same from you.iddqd said:Umm. Who the fuck do you take me for?
iddqd said:I've never owned an open-core CPU, so a bit nervous about crushing it... But the DTR is so cheap... decisions, decisions.
