I recently decided to get a wireless card for my laptop so it'll be useful for something when I take it to class. I, of course, checked newegg first. I'm just going to be surfing, maybe a bit of research, so all I need is a simple card with all the crazy security my university uses. I found this card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124192
$20 not bad at all
But this would be the second card I'll have tried to put in this laptop. The first caused the system to lock up until it was removed. (The same card did that to every laptop I put it in, so I figured the card was crap). Anyway, to avoid this problem again I wanted to get the same card from a retail store so i could return it if it didn't work. So I decided to check the Fry's website to see how much the same card is at their store.
http://shop3.outpost.com/{ogpAWW3oA...w-TUexT4Q**.node3?site=sr:SEARCH:MAIN_RSLT_PG
$50!!
That's a 150% markup, 100% if you count shipping. That should be illegal.
$20 not bad at all
$50!!
