Thanatos.
- Jun 24, 2005
So I recently got a SN25P and got it put together and running but i ran into a snag with my videocard for it (7900GT) the problem is that the power supply (350watts) only has 2 molex connectors on one line one of those is connected to my DVD Burner and 3 sata connectors 2 of witch are connected to hard drives, So I have one empty molex connector and one empty sata connector. The PCI-E power adapter for the vid card I have requires 2 molex connectors they also suggest connecting to 2 molex connectors on separate lines but I only have one line with one open molex end.
So as far as I see my options are buy a sata DVD burner and hook both molex ends to my video card or buy a sata to molex adapter and hook one of the molex from this and my empty molex to the video card. So my question is this which do you think would be the better option and would either of them provide enough power to the video card.
