shadowbreaker513
- Feb 15, 2005
Ever since my video card died (Silly 7900 series), I've been on my dad's computer, and as such, it has seen FAR more use than it ever did since I built it. (Used from parts from my old computer, so it was fully capable of running games still. The problems have been mostly severe artifacting, usually to the point where the computer would lock up. I called BFG's tech support, and they said the usual "reinstall drivers" routine, and to both mine and the tech's surprise, it worked, if only for a time. A week or so later, it happened again, so I installed the older, more stable version of the drivers. This held fine until earlier today. I was playing WoW and suddenly started to get SEVERE artifacting, and the computer locked up within 2 minutes of it appearing. I rebooted into safe mode, and began the usual routine to reinstal drivers. However, this time it hasn't worked. Now the computer works fine, save for a few odd color spots here and there, until I boot into WoW, which I assume would mean that it's shot for all 3d applications. There is severe artifacting in game, that, for some reason, disappears whenever I press print screen, but it then continues to follow to the desktop, and this white box has artifacts as I am writing it. The screen also blinks from time to time (the computer still responds during this 1-2 second blink however). So, do I have another dead/dying card on my hands? Or is there some solution I am missing? Temperature is not a problem as the card is sitting at 62C. On hotter days and when it needs cleaning, I've seen it bump up to 72C after several hours of WoW, but never higher. Is this fixable, or should I begin the process to RMA a second card in 2 weeks?
