Just thought I'd post my impressions of these things here since there is a huge lack of information online on SlickSurf pads. They are pretty much replacement mouse feet for a wide range of mouse brands. The company's website is http://www.slicksurf.com/.
Now on to my review and story!
I have a Logitech MX510 mouse and I had lost a foot a while back. It didn't really bother me until I decided I needed a gaming quality mousepad to fit my gaming quality mouse. I ordered an Icemat from newegg and began the hunt for replacement feet.
Xoxide had some for around $7 + $5 shipping, but that was out of my price range for a simple mouse foot replacement. So I surfed the net and found some random forum post that linked to the slicksurf site. I checked them out and figured that $5 isn't too much money to pay and it wouldn't be a huge loss if they didn't work as advertised.
My Icemat arrived on Monday (I paid the extra $2 to get it sooner) but my SlickSurf pads hadn't come yet. I saw that the Icemat came with some huge plastic feet and teflon tape to put on the mouse. I figured that I'd use this option instead. So I plopped on the too-large feet and stuck on the teflon tape and enjoyed several hours of high-accuracy 'BOOM HEADSHOT' action in Counterstrike.
The next day the neglected SlickSurf pads came in the mail. I was hesitant to put them on because the Icemat teflon thingies were doing pretty well as was. I took a look at the underside of my mouse and saw that the teflon tape was starting to come off and some of the glue from the tape was getting on the Icemat. I peeled off the failed tape strips, removed what remained of the original mouse feet and put on the SlickSurf pads.
And the end result? I am very impressed. The SlickSurf pads are just as good if not better than the teflon that came with the Icemat. The main problem with the Icemat is that if you aren't using any kind of friction reduction for your mouse, you will get an annoying glass scraping noise. The SlickSurf pads actually produce LESS of a noise than the teflon pads did and this will probably go down further as I wear in the SlickSurf pads.
So overall, if you have an Icemat or any other high-end mousepad or just need replacement mouse feet for your existing mouse, try out SlickSurf. I'd post some pictures of my mouse with the pads on, but the images on the website pretty much mirror my results (only the mouse is different.)
