So this is unfinished but I sorta lost interest as always lol...
FlexATX board, 4GB RAM, 3.0Ghz c2duo, onboard video, 60GB laptop drive, Pico PSU.
You can see the ATX connector used to connect a Dell power brick from a laptop. Not all the pins are used, only the center 8.
The two sides are junk PCB. The 120mm fan is a Yateloon at ~7 volts or 700rpm which is about 20dB.
BTW Yes there is a slight bend seen in one of the PICs.... I just half assed putting the side on for PICs.
--edit--
Here is a picture showing how the power brick connects... this from a couple weeks ago I guess when I was testing the picopsu out...
--edit--
