I want to run the VMware client. Will it run in the background of Xp Home?
E6400, Asus P5l-vm, 1gb DDR2 800, 310fsb - 2.47ghz.
If VMWare server runs on your machine, yes.
I can't find the thread you're talking about; can you link it?There is a dual core patch mentioned in the long SMP thread at F@H Community Forum. I installed it on my X2 3800 and it made the times correct.
best I could find:I can't find the thread you're talking about; can you link it?
Any chance of getting this put into a 32 bit distribution? My crappy T2400 laptop doesn't support 64 bit and it is pissing me off Damn Thinkpads...
you could run VMWare on Linux. If your CPU has VT, then you can run a 64-bit guest on a 32-bit host.
No can do. The SMP client requires 64-bit ops, so this does too. You might be able to update to a T5600 or T7200 CD2 that does do 64-bit and VT. I'm not sure how far you have to go to get this to work, but it looks like both of those chips should have support for this. Be sure to report if it does work - I have a T2300 desktop right now that I'd love to be able to run this on.
I just linked this thing on FCF. I hope this takes off
Trying to get this running on a Intel 925 (3 Ghz P4) which supports virtualtization and supports 64Bit. 64 is turned on in the BIOS.. any ideas on why this keeps failing?
http://www.intel.com/products/processor/pentium_d/specs.htm
According to that, it doesn't support VT.
Wait you need VT to run it in vmware? I'm running it just fine in vmware using my 3800 X2 .
Yep. Only the 9x0 series has VT.
AMD chips also have virtualization; I can't find a link right now.
AMD introduced VT with AM2. Not sure if the sempr0ns have it.
To be clear, VT isn't required, but it brings a not-insignificant performance boost.
A VMware VM with a 64-bit OS wouldn't boot up on this C2D I have here at work until I enabled VT in the bios.
For some reason, Lenovo disabled VT in the BIOS of many laptops. I have a C2D, and VT is a no go.No can do. The SMP client requires 64-bit ops, so this does too. You might be able to update to a T5600 or T7200 CD2 that does do 64-bit and VT. I'm not sure how far you have to go to get this to work, but it looks like both of those chips should have support for this. Be sure to report if it does work - I have a T2300 desktop right now that I'd love to be able to run this on.
That is an intel-specific problem. You can find it in the VMWare forums/ KB.
Workstation 5.5 and VMware Server 1.0 support virtual machines with 64-bit guest operating systems only on host machines that have one of the supported 64-bit processors:
* AMD Athlon 64, revision D or later
* AMD Opteron, revision E or later
* AMD Turion 64, revision E or later
* AMD Sempron, 64-bit-capable revision D or later (experimental support)
* Intel EM64T VT-enabled processors (experimental support)
Sounds like it's required to me....
Is stepping F = revision D?Found this: "AMD-V is present in K8 AMD processors from stepping "F" onwards."
cat /proc/cpuinfo | grep flag
gwk@deb-serv:~$ cat /proc/cpuinfo | grep flag
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt lm 3dnowext 3dnow pni lahf_lm cmp_legacy
gwk@deb-serv:~$
gwk@debian:~$ cat /proc/cpuinfo | grep flag
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt lm 3dnowext 3dnow pni lahf_lm ts fid vid ttp tm stc
Is there a link someone can throw up that lists what intel CPus have VT and what CPUs have EM64? Trying to get together my next round of purchases and dont really want to pay Dell pricing for C2Ds
Orthos and everything. Weird thing is, it was crashing at stock speeds (266FSB, 2.13GHz, stock volts). I raised my settings to 333/2.66, and it's been doing better now! I had one problem with my USB HD, but I switched it over to internal and it's been good since. I'll poke around some more later.No idea, mavalpha. Are you sure your machine is stable? Run Memtest recently?
It isn't a problem, it's a screensaver. Hit the Num-Lock key or move the mouse, and your screen should come back up.Well, I've got the VMware thingee running, and all looks fine.
However, after a while (not sure exactly), the terminal window just goes black, and shows nothing. When I reboot the VM, it shows that progress has been made however.
Is this a common problem, or what? I just like being able to keep tabs on everything, and since the log file is kept stored in the virtual disk which I don't know how to access, I'm kinda left guessing, ya know?
-Ghent
