So I take a look through my case window and see what do I see? Water dripping onto my vid card. Thanks to this:
http://im1.shutterfly.com/procserv/47b7d807b3127cce86580b15f4ad00000026108QctnLRq0aM
http://im1.shutterfly.com/procserv/47b7d807b3127cce86580b2ff49700000026108QctnLRq0aM
http://im1.shutterfly.com/procserv/47b7d807b3127cce86580b0bf4b300000026108QctnLRq0aM
Ouch, if your GPU isn't dead already, get it out and wipe off the water quickly. Use some rubbing alcohol to clean it off, let it dry, and pray then
That really sucks, I'm pretty sure that's acryllic, rather a more flexible plastic. And even using non-NPT barbs
I've never been a fan of acrylic tops for this reason.
Replace it with a Apogee GT or other water block of your choice and you'll be back in business.
Agreed. Swiftech MCW60 would be the safer route for his video card if he chooses to purchase another block.
I recommend not over tightening the connectors but am sadened by anybody who experiences water on their video card. Just plain sucks.
Thinking back to my poor 9700Pro that couldn't swim........
Not all cracks happen due to over tightening. There's a horror show thread over on XS of random cracks occurring 3-6 months into usage across a variety of manufacturers. There's a reason why DD and others moved away from acrylic tops.
It's blingy yeah, but the risks are just not worth it.
I told myself that I wasn't going to play on these WC forums anymore, but I got a invite and just had to make my standard acrylic comment........ The stuff is dangerous, it will sooner or later crack, there are other types of materials out there better suited for the manufacture of water block tops (Swiftech). So save your self some money and your computer, and shop around.
Actually most of the cracking problems were solved with they (Dtek, DD, etc) went to new fittings that included an o-ring instead of pressure against the threads to seal the barb to the block........
I have to agree with this. I don't consider myself a water cooling expert but it's not hard to understand that acrylic isn't the best material to be using for water cooling hardware. It's brittle and cracks easily. Fact is it's inferior to other materials.
My personal opinion on this is that it isn't the material that's the problem, but the way the material is used by various manufacturers. Plexi is clear so it adds some bling to the party and it also allows visual observation of what is going on inside your block without having to take it apart. We also have to remember that not all plexi is the same. There are different grades of the stuff.
The glaring things I have noticed about these cracks are that they are all have used thin walls. The other thing we used to see is manufacturers here that used NPT threads. It doesn't take a rocket scientist to figure out that using a tapered thread causes a disruption of the material as the fitting is tightened up. The other issue is with tapping is you need to be very careful with exactly what kind of tap you use and the thread specs. All G 1/8 threads are not the same. I have seen some manufacturers who have used taps that produced tight threads either from poor tap design or the tap wore out and they kept tapping.
All my Aqua Computer BSPP threads are a bit on the loose side which is what you want because the fitting doesn't seal on the threads, but on the o-ring. AC recommends that you just use the fittings hand tight to sustain a good seal. Even knowing this I usually add a slight (1/8 th) turn to the fittings with a wrench. The threads being a bit on the loose side can only be made with special taps that other manufacturers may not spend the money on.
So from my perspective it isn't the material that should be in question, but the manufacturer who made it. Buy from high quality manufacturers and this problem shouldn't be evident.
That's ok, I must not have tightened my barbs enough on my MCW30 because I had a leak all over my motherboard and one of my GPUs. Fortunately the leak wasn't too bad and I was using non-conductive coolant. More expensive, but worth it.
I don't believe any legit manufacturer has used NPT threads for the longest time. EK has used BSPP since its inception. Swiftech has used NPSM (basically the same thing except for thread count 18 vs 19) for the longest time and recently switch to BSPP. D-Tek uses BSPP. BSPP threading is irrelevant to the discussion as of today's components for the most part.
Whether its alphacool, EK, aqua computer, or DD, acrylic/plexi can crack. Now if the user wants to deal with the risks, by all means, (I roll the dice too on occasion). However, I think it'd be best if all manufacturers offered a delrin replacement top if they choose to offer acrylic tops. Delrin tops don't run the risk of cracking like acrylic tops. They can withstand torquing of barbs/tubing/temperature changes/alcohol/etc like a champ.
The block was doing well with no problems since November, until it cracked. I did not use alcohol so I don't think that was the problem. Before buying the aquagate, I remember reading a few threads on the CM forums where some have reported the same problem. I was just hoping that I would not be one of them.
. Just like I won't use aluminum blocks. They just don't make sense to me.
Not that you can see the thread for the next 7 days considering the mods banned you over on XtremeSystems, here's the most recent acrylic crack thread (along with corrosion): http://www.xtremesystems.org/forums/showthread.php?t=147847&highlight=thermaltake
There's another thread with an EK crack, DD crack, and a Zalman crack. I'll search for it when I have time.
I believe it was for a variety of reasons as told to me through PMs with both mods including:I knew getting banned was coming up real fast when I challenged XS about their Aluminum Censorhip. No big deal as they have also locked all the threads now that had good things to say about using aluminum in a water cooling circuit including the one called What's up with the Aquaduct?.
Ah yes, manufacturers, retailers, block designers, established WC'ing pioneers and gurus...XS is definitely the backwaters of the WC'ing community.I probably won't be back as they are some of the most incredibly closed minded group of people I have ever had the misfortune to run across. I will leave them and you to wallow in your ignorance.
BillParrish said:cast acrylic is a lot like tempered glass, a flaw or a stress crack. from manufacturing or over tightening the fittings by the user, can lay dormant for a while and then a small change, thermal, air pressure, shock, and the damn things crack badly/shatter.
After looking at this tread and the links to the ones at XS, I havent seen such a witch hunt since Salem in the late 1600s. (and I was there) All TN does is ask questions or show information, but gets constantly attacked. Very sad.
