I want my SLI multimon NOW!
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9660&Itemid=1
Nvidia plans to launch a new brand and it will simply call it SLI 2. Like the logic implies SLI 2 will be better than SLI and it will actually mean you will have more than one graphic card rendering your graphic and an additional card to do your PhysX.
SLI 2 = SLI + PhysX and this cannot be more simplified. We dont know when will this launch but the new driver that supports PhysX is finally out so any board with three PCI express slots should be able to cope with this new SLI 2.
This will look good on new boxes but as you can see its not anything spectacular. We will keep our eyes on when will this launch.
I wonder if SLI 2 and Big Bang II are one in the same?
I would say more then likely they are, the big band 2 was probably their code name for it.
My guess, only if you're using a very old driver version ATM.Do these drivers increase performance a lot even if you dont use SLI?
Im hoping they fix the issue with using two monitors at once and running games in windowed mode that drops performance by 60%
I'm guessing that if you've been updating all along to the latest driver releases and betas, the official release Big Bang drivers won't have that much new to you.
Yes... Forceware 180.10Still nothing huh???
Does anyone know if its limited to 2 monitors like crossfire?
I can confirm that the drivers available for download right now require Vista 64bit, a Geforce 9800 GTX or GTX+ or GX2 or a 260 and 280. Nothing lower is supported in this download.
These are still BETA, so there still is hope...
Yeah? Well with a 9800GX2, that's what you get no matter what! The same message about "connect them both to the same GPU" except the video outs are connected to DIFFERENT GPUs by design... GX2 = teh screwed, AGAIN. *kicks self for not waiting for GTX280*
