holli4pirating
- Nov 13, 2005
I've finally started folding on server (listed in my sig).
I went through the config guide on hardfolding, and at the moment I'm running 4 instances (1 per virtual core), each set with 128 megs of RAM and running at 50% core. I might up the ram and core depending on how much it impacts the server's normal functions (it's a fileserver for about 15 people). So with that out of the way, on to the questions.
On the four instance I just started, they have different total steps (one is 2mil, the other are 4 mil). What causes that/does it matter? They should all have exactly the same configs.
How often does it update the number of steps completed? They've each been running for about 30 mins and there has been no change on the screen.
I tried searching the Hardfolding members list for myself, and even though I've created a profile, I'm not getting anything when searching for myself. Is something wrong, or does it just take a while to update?
Would I be better off running just two instances (one per physical core), or should I keep it at 4 (one per virtual core)?
If I need to reboot or shutdown, how should I close each instance of folding so as not to lose results? Is there a pause or halt command?
I think that's about all for now, but I might have more questions as time passes. Thanks for any help or insight that you might be able to provide.
