At 1280x1024, your CPU is a far more pressing need than your video card. I don't think it would help at all to be honest.
edit: Oh, I thought you were talking about adding another GTS. Really it's hard to say. If you overclock your CPU to ~3.0GHz, I could see a GTS 320 doing decent at that res, at least from what I've heard from the beta, but I'm not really sure how important the CPU will be. My advise at that resolution would be to try to find a cheap dual core skt. 939 cpu OC the crap out of it, and pair it with a GTS 320.
This would be ideal: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103052 Should be good for reasonable clocks and won't break the bank by any means.
He's on socket 754, so it's damn near impossible to upgrade that CPU with a new mobo and RAM.Drop in an X2 3800+ F3 or a 3600+ and OC the hell out of it. Cheap and the GTS will get fed properly.
a 3800 x2 AM2 oc'd to 2.5 and 7800GT can not play Crysis very well with EVERYTHING on low so I think you'll have a hard time with your set-up also.
Where are you getting this?
a person in beta
Pretty much the case, yeah. My cherry-picked Opteron 170 barely hits 2.8 under the cooling prowess of the almighty Storm G5, and 2.9 might be possible, but you'd might as well forget about stably passing about 2.7 on stock air on the 3000+.A64s are horrible overclockers, at least in comparison with the C2Ds. There is no way youi'd get the linked chip to 3Ghz without phase or similar.
I have a sneaking suspicion that Crysis isn't going to be nearly as well-performing as we've been led to believe. I wasn't blown away by FarCry, and I don't truly expect much from Crysis. I think folks who've been feverishly upgrading to get rock-solid frame rates are going to be somewhat disappointed. My two cents.He's telling the truth, my friend is in the BETA also. And his computer isnt that bad yet. But, it runs like crap ( looks nice while doing so though ) on all and every setting and res.
I have skt 754 though...
Also, overclocking a ancient 3000+ to 3ghz? I thought A64's were pretty poor overclockers? I also am not experienced at overclocking, highly value stability, and assume I'd have to buy at least an expensive heatsink (using stock now) to do that, mitigating any savings.
I think I pretty much know the answer to my own question, it's not gonna work.
The price of an upgrade to a low end Core 2 dou, new mobo, and couple GB's RAM is pretty darn reasonable, about 300. But hey, 300 is 300, and I'm poor.
Actually I can even do a 4400X2/mobo/ram rig for about 200. But, it just seems stupid to me not to spend an extra 100 on a far better rig since I'd already be in for 200.
I know I just said I dont know much about OCing, and I dont, but I plan to most likely OC that hypothetical Core2dou purchase. I know all those suckers go to like 3ghz. I'd be happy with something like 2.6 just for the stability.
And oh yeah, the kicker expense to all this is, I have to buy Vista on top of all the other crap as I'm on XP.
Simplle as above. I assume I'll have to do a total system rebuild. But, I wish I could just drop a 8800GTS in for Crysis. How stupid would it be? Gaming at 1280X1024.
