Ok I've spent over a day reading this ENTIRE thread... Often off topic and not very concise.
Anyway we've got the following monitors which are currently available:
The new dell is almost exactly the same as the older 3007WFP-HC but uses a newer panel and or backlighting which gives better color and improved response times. So definitely better and should always be picked above the standard 3007WFP, unless you're able to get a stellar deal on the older 3007WFP.
The new Dell 3007WFP-HC supposedly uses the same panel (S-IPS) as the HP LP3065, so features and quality wise very very similar. They differ in that the HP has 3 DVI dual link inputs where as the dell has one. These extra two inputs can only really be connected to computers which are able to provide the required resolution to drive the monitor. So not really that useful unless this is what you're after. By the sounds of it the HP doesn't natively support the 1280x800 over single link DVI??? Which could be useful (e.g. connecting up an older computer that doesn't support dual link). It seems the consensus is that the Dell looks a little "prettier" (both the monitor and the stand) compared to the HP. The Dell is also the only monitor supporting the built in card reader hub.
The Samsung 305T uses their own S-PVA panel, so has both benefits and drawbacks compared to S-IPS. Seems like most lean towards S-IPS, even though the difference isn't too major. The big missing feature of the Samsung is HCP, which isn't to important now, but may very well be in the near future. Again the 'looks nicer' than the Samsung which has quite a plain looking stand. The Samsung has one DVI port and a USB hub.
The Apple 30" uses the oldest technology, and is the most expensive. So the worst deal really.
There was a Benq 30" monitor many were waiting for, but they have no plans of releasing it anytime soon. It was supposed to have many different input types and a built in scalar.
Other factor to consider is return and dead pixel policy, which is *fairly* similar between brands.
A fairly good review which compares the new Dell 3007WFP-HC and Samsung 30" 305T:
http://www.behardware.com/articles/661-1/the-new-30-inch-monitors-dell-and-samsung.html
So overall it seems to me like the Dell 3007WFP-HC is the best choice price being equal...
Future 30" Monitors
There are new panels being released this year mostly based on Samsungs S-PVA panel (seems Dell, HP, Apple etc will be using it). And *probably* no more S-IPS panels??
LED backlighting will be used in new monitors released towards the end of this year, which will provide improved color (and supposedly longer life). Seems this will be quite expensive when released but will eventually come down and meet non LED panel pricing.
New 30" monitors being released this year are also rumored to have built in scalars and OSD (which non of the existing monitors have). I guess this is a nice to have so long as it doesn't add to much onto the price. But for strictly professional use and getting the most out of the monitor not required at all, everything can be done by the video card.
I think this is largely a summary of where everything is at - at this point in time.
On too the questions...
I'm wanting to purchase a new 30" display. Currently I'm using a 22" Mitsubishi Diamond Pro 2070SB CRT monitor. Which cost slightly less 4-5 years back when I bought it compared to these 30" displays.
Currently Dell has a special offer that I'm thinking of taking advantage of...
These are my ranked choices along with what it'd cost me to get them.
Costs vary quite a bit depending on country so I'm just wondering on your opinions on which to get based on the relative pricing? Or is it really worth waiting for a newer panel? Is the picture/color quality really going to be much worse than my CRT? I'm a website developer, mostly coding, occasional graphics, and yeah gaming. So reasonably decent color is important to me. Oh and I'm wondering if it's worth paying to up the 3 year warranty?
Thanks,
Shaun
- Dell 30" 3007WFP-HC
- HP 30" LP3065
- Samsung 30" 305T
- Apple 30"
Future 30" Monitors
- Dell 30" 3007WFP-HC NZ$2199 (~US$1649)
- Samsung 30" 305T NZ$2140 (~US$1605)
- HP 30" LP3065 NZ$2445 (~US$1833)
Thanks,
Shaun
