Order said:Does such software exist?
I know that there are various router programs that come close but if I want a full-gigabit L3 switch is it possible to build it?
nebruin said:Well a true switch would be almost impossible, since there are almost no real many port (ie more than 2) based NICs. If you just want L3 routing at gigabit, then install 2 or more nics and then plug them in to L2 Gigabit switches, then just install some linux varient of routing software. Although you will need to put it on a decently beefy machine if you want to be able to route at full gigbit speeds.
moetop said:Can you better explain "almost no real many port (ie more than 2) based NICs" , when a froogle turns up a good selection of 4 port ones. We use a lot of them as well at work. Am I missing something concerning multiport NIC's ? Is there a throughput issue ?
sandmanx said:Notice in the link you have, they are all 100Mbps(at least at a quick glance). 1000Mbps Ethernet completely saturates a standard 32bit 33MHz PCI slot. You need more bandwidth to even fully use 1 port, much less 2 or 4. You also need a lot of cpu power to get full use out of those Gbit ports, since there are so many interrupts due to the frame size being the same as 10 and 100Mbit cards. A standard PC simply does not have anywhere near the IO bandwidth to do any heavy duty switching.
PHUNBALL said:You are correct, multi-port NIC's are common in some environments... Either way, adding a bunch of NIC's to a PC (whether they are multi-port cards or not) still does'nt make it a switch, it's still a router...
Order said:I have all the media (ie: educational DVDs) stored on the server and will be streamed via the network to whichever client requests it. It might be concurrently, it might not, but I need the bandwidth to handle that along with usual file transfers, backups, and eventually VOIP.
