I need to shrink a non-OS 3TB hard drive's only partition to create a second partition. Is Windows 7's built-in facility reliable enough, or is it better to use a third party tool like Parted Magic?
It should go without saying that you should backup all the data that's important juuuuust in case things don't go right. Chances are slim that you'll have a problem, but if you do you'll be happy that you have a backup
the easeus products have always worked wonders for me. i didn't realize win7 had one that could shrink. always back up your data. we're all assuming you have data on this 3tb drive but if it is empty, then just delete partition and repartition via windows disk management.
