First off is it worth water cooling a 3700+? It is going to be attached to a Abit Fatality board, and Corsair XPS PC-3200 LOW CAS, X850XT PE PCIE
2nd) what would be better for cooling or more worth the money? I dont want none of these it is not worth water cooling it and then you say nothing more.
3rd) OCing is a must, if you knew me then you what know why.... What is the best way to OC this bad boy and how high can it go too? Is there a better CPU to OC for around that same amount of money
Thanks again guys, See sig and you will know I am a noob for the most part about AMD but not at all on water cooling, that is my second kit and I have worked on many more
